Any difference between these cards?
Go to solution Solved by minibois,
The difference is the clock speeds. These are out of the factory speeds which you can easily change, the difference between the cards' clockspeeds is so small all cards will be able to achieve those speeds. Get the cheaper one.
So I've been planning to buy a gtx 1070 and I've come across two different ones. I'm unsure of which to buy as the specs seem the same and they both come with Watch Dogs 2. As one is $20 cheaper would I be giving up any performance between the two? Thanks for any feedback.
The cards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125871&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125875&cm_re=gtx_1070-_-14-125-875-_-Product
https://linustechtips.com/topic/709053-any-difference-between-these-cards/
One of the cards has a slightly overclock. I would buy the cheaper one and overclock in manually.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
