I turned all the fans in my PC on silent mode in my motherboard's BIOS but they still run at over like 1000RPM on idle, and they ramp up even more under load. What fan speed control software should I use so I can allow my PC to be quiet and only get louder when it's under load. Thanks!
https://linustechtips.com/topic/709026-fans-run-full-speed/
msi afterburner
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/709026-fans-run-full-speed/#findComment-9053844
What brand is your MoBo? If it's Asus they have fairly good fan control software that links with the BIOS.... most of the time.
https://linustechtips.com/topic/709026-fans-run-full-speed/#findComment-9054182
