Will 4+4+8+8 work for ram?
Solved by ARikozuM,
18 minutes ago, sazrocks said:
You can mix size for each channel (with A1 and B1 being a dual-channel 1).
If you were to mix a 4GB and 8GB into the slots (A1 and B1), you will run 8GB in dual channel with the remaining 4GB being single-channel. Same for slots A2 and B2. This is quite common on Micro-ATX and Mini-ITX boards with 2 slots vs 4.
If you were to place the 8GB sticks into A1 and B1 alongside the 4GB sticks in A2 and B2, you will be in dual-channel for both.
