Idk the name Now I do know the name. I would like to say it looks fancy but is probably overpriced. Therefore I am also interested in finding out what that thing is.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/707747-front-panel/#findComment-9040757
This: https://www.amazon.de/INTEL-Server-System-R2224WTTYS-Incl/dp/B00QLRKLJ6
Google reverse image search makes it possible. Everyone should know how it works.
3.Use
https://linustechtips.com/topic/707747-front-panel/#findComment-9040760
