Posted December 16, 2016 I am going to build a PC soon, and I'm wondering what case I should choose, My current planned build https://pcpartpicker.com/list/LTtrqk Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/ Planned Build : PcPartPicker Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 24 minutes ago, CHILDISH_K1LL3R said: I am going to build a PC soon, and I'm wondering what case I should choose, My current planned build https://pcpartpicker.com/list/LTtrqk if your going 144hz at 1080p i would get a 6700k Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038041 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 Author 15 minutes ago, 8-Bit Ninja said: if your going 144hz at 1080p i would get a 6700k i7? Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/ Planned Build : PcPartPicker Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038066 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 Just now, CHILDISH_K1LL3R said: i7? yep, the i7 6700k is much better at holding high frame rates, which you will need at 144hz Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038068 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 Author 1 minute ago, 8-Bit Ninja said: yep, the i7 6700k is much better at holding high frame rates, which you will need at 144hz Too much $$$ Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/ Planned Build : PcPartPicker Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038073 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 4 minutes ago, CHILDISH_K1LL3R said: Too much $$$ cut down on other areas, but you're going to have a bad time at 144hz without it Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038079 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 16, 2016 12 minutes ago, 8-Bit Ninja said: cut down on other areas, but you're going to have a bad time at 144hz without it There is little to no difference between 6600k and 6700k and same clock speeds. Even in CPU intensive games. Link to comment https://linustechtips.com/topic/707554-coolermaster-mastercase-problem/#findComment-9038102 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
