Im wondering how much data my server is using per day on my wifi bill.
In Ark, the Ulrta upload speed is 60Kb/s
If I have 1 person connected to the server, and they are on the 60kb/s upload to the server and play for say...6 hours to make numbers even. How much data will be uploaded/downloaded in those 6 hours?
https://linustechtips.com/topic/707169-how-much-data-am-i-using/
depends on the bitrate.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033598
probably variable. You'd have to check the video output settings or sample an outputted video.
ETA: you could probably extrapolate based on average bitrate, but that's not the whole story, usually.
System specs:
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033616
your not making any sense...Ark is a game. The upload speed to the server is 60Kb/s
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033624
Then take (60 Kbits x 60 seconds x 60 minutes x 6 hours) / 1024
= 1265.625 Megabits
158.2 Megabytes
Also, make sure you know the difference between bits and bytes. Here's a recap: 8 bits = 1 byte. :)
B = Bytes
b = bits
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033671
OH i thought this was a video streaming thing. very one sided connection.
as with any connection, the use is based on uploads and downloads. if you get 100MB of bandwidth, that could be 50MB uploaded and 50 MB downloaded, or any combination of the two adding up to 100MB. every packet that does out must have an ACK packet in response and vice versa. The player could litterally sit in one area and not do anything and have very low output or they could max out the connection and end up with the numbers @Freezanator gave you.
it is quite actually highly variable.
System specs:
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033703
so depending on if the player is doing anything or not, the value varies? like they wont use the full 60kbs when just sitting around
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033716
not likely, but again that's predicated on what comes down the pipe from the server.
ETA: If your server IS PUMPING 60 kb/s all the time, then the worst case is slightly worse than the numbers given before (multiple connections to support said connection).
System specs:
https://linustechtips.com/topic/707169-how-much-data-am-i-using/#findComment-9033743
