Hi Guys
I had watched this video many times and wanted to setup my PC just like that but I encountered a problem. The problem is my CPU is one room and I have to give the IO connections in 2 different rooms which are kinda far from the room where my CPU is and installing HDMI/VGA cable and USB cables will take lot of time and money so I need your advice to implement the same without any hassle of wires. Any advice and inputs are welcome. Thanks
https://linustechtips.com/topic/706201-connecting-cpu-and-io-wirelessly/
For starters, the whole PC isn't a CPU. Not sure why people can't understand that, but there you go.
As for the question at hand, you can just get a KVM switch of some sort. But those alone will probably end up running you 40+ USD at least because most of the basic ones just have VGA and a pair of PS/2 ports.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Aren't they make any wireless thunderbolt hubs kinda thingy??
No, because Thunderbolt uses a speed that's too fast for any wireless standard can use.
If you want something completely wireless, you'd have to get something like an HDMI wireless transmitter, a wireless keyboard, and a wireless mouse.
Adding to this:
Those will have limited range and will not have solid connections to the computer, unless you spend a fortune on them.
This. Or accept the latency penalties of using a solution like remote desktop (VNC) with a compute stick plugged into your monitors/keyboards/mice and preferably wired into your network to decrease the latency.
Personally, I think the best/cheapest option for you would be to punch a small hole through your wall and run a HDMI cable + USB extension through it.  If you want to make it look nice you can get one of these (wall grommet):
I wouldn't recommend a wireless solution because you're bound to have latency issues and occasional hiccups. Just keep in mind, that if you go more than about 5m with the cables you will likely need a booster/active cable (particularly for the USB).
You can also use a remote desktop connection to broadcast your desktop to another device. Pair that with a PC on a USB, a Raspberry Pi, etc and you can run your computer off any other device. It will take a bit of googling but can be done easily. You can also use your home wifi and a number of phone apps to control your PC wirelessly using your phone as a KB/mouse.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
14 minutes ago, kingslayer said:
If there is any dongle or something which I can attach in my USB port on TV which can connect to my Wifi router and also connect my wireless keyboard mouse and HDMI TV? Just a thought.
There is this option: http://a.co/hfd2O9O (it's like a chromecast but for PCs).  Kep in mind that it requires a PC that supports miracast.
There are also these: http://a.co/096av1r which are entire PCs on a stick and plug directly into an HDMI port on a TV.
I've often wondered, how do you use a Raspberry Pi as an RDP client?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
2 minutes ago, kingslayer said:
That's make two of us.. I tried googling it but I think I need help in that sector as well :P
Yeah, all I found was some thin client software with broken English.
Main System: Phobos
Installing Windows XP or any version on Raspberry Pi and connecting it to main CPU? How's that sounds like?
You can't install Windows on the RPi as they have ARM CPUs.
Main System: Phobos
You could however get a cheap Dell Optiplex FX thin client from eBay and use Windows XP Embedded with Remote Desktop.
Main System: Phobos
1 hour ago, kingslayer said:
How about the performance on 1gb ram?
Windows 10 runs fine on tablets with 2GB of RAM.
But also dat assumption that ARM based systems lack RAM. My phone has 3GB of RAM.
He was making the comment about the Raspberry Pi specifically. And Windows 10 tablets with 1GB of ram work, they're just slow.
There's software that lets you run x86 software on ARM. a quick google search came up with this guide to run teamviewer on a Pi (https://eltechs.com/run-teamviewer-on-raspberry-pi/). There were a ton of other methods that popped up in the search too.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
If we're talking about that, then it's the IoT Core version of Windows 10, which is a heavily stripped down version the OS.
You could also probably tweak those 1GB tablet versions to make it run leaner.
What about VNC?
