https://linustechtips.com/topic/705436-custom-cooling-solution/
Not sure what you mean? Do you want to hook a shop-vac to your cpu? Because they're loud as hell and not rated for 24/7 operation.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/705436-custom-cooling-solution/#findComment-9013436
just want to try it as a experiment on a old 775 mobo
https://linustechtips.com/topic/705436-custom-cooling-solution/#findComment-9013441
Well if you want to you'll still need to hook it to a heatsink of some sort to disperse the heat. Again you'll only get an hour or two at once because those motors overheat after awhile.
https://linustechtips.com/topic/705436-custom-cooling-solution/#findComment-9013449
