Please Help,
At random intervals I notice my screen blinks black for about a whole .5-1 second at just completely random intervals.
Whether in Firefox, in game, steam, wherever I am at. I find it gets even worse whenever I have to alt-tab. It has been doing this since
Thursday when I logged in. After being annoyed by the blinking I updated from 375.95 to 376.19 in nvidia (I have a GTX 1070). My
Monitor is brand new and I tried replugging HDMI, I made sure PCIE was secure, etc to no avail. I tried going through Task Manager. Nothing. I tried checking
Super Anti-spyware and Malware-bytes. Nothing. Not even a cookie. Do I have to update chipset? BIOS? Revert Nvidia? Reinstall OBS? This blinking is
slowly driving me nuts so I would like some help. Thanks in advance.
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/
13 minutes ago, TheGleaner said:
Maybe the update messed something up? Otherwise when this happened to me I had hardware failing.
Highly doubt it. My GTX 1070 is 5 months old and has been perfectly fine. I have proper motherboard, PSU is 650 watt thermaltake. Mobo is MSI m81-e33. CPU is i7 4790k. I highly doubt it. I use HDMI 2.0 for monitor and that has to be fine.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013479
Well in March 2017 I am considering a new build anyways but I will reuse some components.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013483
8 minutes ago, TheGleaner said:
Have you tried other outputs, such as DP, or using the integrated graphics, and referring to the part about the brand new monitor, remember, even with today's technology you still could have gotten a bad one
I just tried moving HDMI on graphics card and TV so let's see if I get any blinking
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013541
ANNNDD That didn't work I'm getting blinking again
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013558
I have my xbox also hooked to monitor so let's see if it is that.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013560
Have you tried a different cable?
I just tried Xbox and played game, flipped through menus, etc and it didn't blink. So it is down to either the cable, video card or windows. I will try a different cable. I will switch xbox cable to PC and PC to xbox and test both.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013574
Ok after flipping the cables I have determined it is not the cable. As I was eventually able to get the blinking again and not cables and HDMI are switched so it is a matter of video card.  I think attempting on board graphics ports will be reasonable as that will determine if I need to refresh windows or it is a video card issue.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9013678
Well I have performed a clean installation of nvidia 375.95 so that should help but I could go back to 375.86 if necessary
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9014010
Did it blink on on-board graphics?
The Nvidia driver clean installation worked, No it did not blink on iGPU
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9014432
On 12/11/2016 at 8:10 PM, TheGleaner said:
So are you issue free now?
After a couple of days of simmering. No. I am not. It was problem free Sunday and Monday. Should I reinstall windows? I have been meaning to move it to my SSD anyways. I have probably a little over 2TB of stuff problem is my 2TB External Drive may not suffice for EZ Transfer. Hmm.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9025012
I have a Zotac GTX 1070 Founder's with a 5 year warranty. Should I contact Zotac?
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9025024
Wait I could use windows refresh heard that has a keep my files option
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9025043
Suspect it was windows as it said it installed stuff December 8th when I shut down my PC, the 9th was when I saw issues.
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9025067
I guess you could...
Possibly if it persists
https://linustechtips.com/topic/705433-help-random-blinking/#findComment-9025347
