Hi everyone, for this Christmas i have decided to build my very first PC for gaming. I have looked around the Amazon market and I noticed  Aerocool Xpredator-X3 Devil Red Edition as the best for now. My build will have a MSI GTX 1060 6GB Gaming X, one SSD, two HDD and a Blue Ray reader; so I need a case which have enuogh space for these components (I have already build a PC for a friend, so it would helpful if you recommend a case with a good cable management :p).
https://linustechtips.com/topic/705258-help-choosing-case/
Any NZXT should work, good looking casses
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011809
Have you looked at the NZXT Phantom 410???
https://www.nzxt.com/products/phantom-410-white
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011810
yeah, I looked at that and I saw that with msi 1060 I should remove some cages for hdd. That means I have to not use one hdd since there are only 2 cages.
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011815
H440 Then?? any fractal, nzxt, corsair and cooler master cases are good :)
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011818
 Note: each cage has several slots, so it shouöd work with two hdds and one ssd
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011821
Not sure about Coolermaster Cases, ive build my friends pc in a coolermaster cacse he chose and it was awful, the cable menegment room in the back had not enough space for any power cables , only for front panel cables but they came from the front so that you couldnt route them through there. Worst case i have ever seen
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9011842
1 hour ago, huilun02 said:
Well, yeah. Actually I can't find it in any online store, and from the site of the producer of the case says a reseller that actually have out of order most of the case from Phanteks and they says it will not be avaible until start of jenuary or something like that. Then I looked to it on Amazon Italy but there isn't anything, and the only avaible is a bit too much overpriced (something like 110EUR which should be almost more of 125$). So yeah *crippling depression entisifies*
https://linustechtips.com/topic/705258-help-choosing-case/#findComment-9012598
