I'd just be worried that they used a proprietary motherboard and the PSU won't work for it.
What makes you want to do this instead of just building your own?
EDIT: Nevermind I see. You already own it. Theoretically it'll work. I don't think you need to upgrade the power supply.
9 minutes ago, Droidbot said:
Amazon links work fine, but just not the OfficeDepot one.
Works for me.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/705118-will-this-build-work/#findComment-9010775
