Since my new build is complete and only missing a secondary storage device..I decided to remove my old HDD from my previous computer but it's proving to be difficult.
Two screws came out fine. However, the last 2 won't budge no matter what.
Image of what screw looks like: sLjJw.jpg
Any ideas what can be done here?
https://linustechtips.com/topic/705103-hard-drive-removal/
Well other than "try really hard", here's a wikihow article: http://www.wikihow.com/Remove-a-Stripped-Screw
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/705103-hard-drive-removal/#findComment-9010506
You can buy a screw removal bit from the hardware store.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/705103-hard-drive-removal/#findComment-9010507
Probably should have stopped before stripping the screw into oblivion. You can either get a screw removal kit like Ariko said, or just drill it out and likely destroy the HDD in the process/
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/705103-hard-drive-removal/#findComment-9010524
