Posted December 11, 2016 I Love how they both look. any suggestions on my choice of components? PCPartPicker part list / Price breakdown by merchant CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($329.88 @ SuperBiiz) CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler ($80.88 @ OutletPC) CPU Cooler: CRYORIG A40 83.0 CFM Liquid CPU Cooler ($103.98 @ OutletPC) Motherboard: MSI Z170I GAMING PRO AC Mini ITX LGA1151 Motherboard ($165.99 @ SuperBiiz) Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-2666 Memory ($99.97 @ Jet) Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($164.99 @ Jet) Video Card: Asus GeForce GTX 1080 8GB ROG STRIX Video Card ($639.99 @ SuperBiiz) Case: NZXT Manta Mini ITX Desktop Case ($119.99 @ Directron) Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.30 @ OutletPC) Total: $1794.97Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2016-12-10 22:36 EST-0500 Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Does it have to be small? I would get atx case, and atx mobo for future upgrade. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010206 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Author Just now, PCNoobie said: Does it have to be small? I would get atx case, and atx mobo for future upgrade. I thought of that, but considering SLI is shit, any future upgrade would just be a better single GPU, instead of adding a second one. What other upgrade limitations would I run into? Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010213 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 M.2 drive probably. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010227 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 from what I've read, the A40 isn't the greatest of AIOs it's pretty loud, and doesn't cool as effectively as other AIOs I'd get a Cryorig air cooler instead. Something like an H5 Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+ Smallsnor: Huawei Matebook X Canon AE-1 w/ 50mm f/1.8 lens Pentax KM w/ 55mm f/1.8 SMC lens Zenit-E w/ 58mm f/2 Helios lens Panasonic G7 with 14-42mm f/3.5 lens Polaroid Spectra System Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010245 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 BTW the bequiet cooler can't fit into the case. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010250 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Noctua NH D15 is very quite and one of the coolest (in terms of temperature) cooler. The component you picked is great but why not go for Corsair Vengeance RED LED instead of white? Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010258 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Author 3 minutes ago, PCNoobie said: BTW the bequiet cooler can't fit into the case. I found a couple builds with the same case/cooler. It might be a mistake on the website. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010271 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Author 4 minutes ago, deXxterlab97 said: Noctua NH D15 is very quite and one of the coolest (in terms of temperature) cooler. The component you picked is great but why not go for Corsair Vengeance RED LED instead of white? I was trying to go with a black and white build lol. I was having trouble finding a mobo to fit the theme though. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010286 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Just now, JP3 said: I was trying to go with a black and white build lol. I was having trouble finding a mobo to fit the theme though. Yeah noctua are ugly. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010288 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 4 minutes ago, JP3 said: I found a couple builds with the same case/cooler. It might be a mistake on the website. I can see some builds, but I would consider of the cooler putting pressure on mobo. which would damage mobo. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010298 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 IMO, liquid coolers aren't worth it. I have an H100i and the pump plus 2 fans makes a heck of a lot more noise than a CPU cooler with just 1 or 2 fans on it. Plus, with a liquid cooler, you have to worry about "Will the coolant tubes have enough length to go from point A to point B" and sometimes a liquid cooler can break. For instance, if something happens and a line is punctured or it comes loose from its fitting, liquid will go everywhere and let's just say liquid and computers don't go together very well. An air cooler, if it malfunctions, will normally just cause the computer to shut down due to overheating,and occasionally the CPU can die. A lot cheaper to replace a dead CPU than to replace a mobo, CPU, graphics card and whatever else a coolant leak will destroy HP x360 14, Core Ultra 5, 16GB Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010317 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 And also, you REALLY should not get that ram if you are getting bequiet darkrock 3 because that ram is too tall to install the cooler, and led can't be shown too. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010327 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 11, 2016 Author 26 minutes ago, PCNoobie said: And also, you REALLY should not get that ram if you are getting bequiet darkrock 3 because that ram is too tall to install the cooler, and led can't be shown too. Yeah, I would change the ram to a lower profile HyperX or something if i went with the air cooling opiton. Link to comment https://linustechtips.com/topic/705080-cooling-decisions-first-time-build-help/#findComment-9010420 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
