Hey guys, i found this driver i would like to download but i dont know if this side is legit? Do you guys know the site? http://www.guru3d.com/files-details/amd-radeon-software-crimson-16-9-2-driver-download.html
I just scared if they have virus in the driver ( Its the Windows 10 64 bit one )
https://linustechtips.com/topic/704921-help-for-this-driver/
It's a legit site. But getting it directly from AMD would be better.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/704921-help-for-this-driver/#findComment-9008302
Just now, Gombel said:
As i said, i cant use the newst driver, its working well for me, its makeing some of my programs crash
This is from AMD has all the drivers ever released
http://support.amd.com/en-us/download/embedded/previous?os=Windows
Hello
https://linustechtips.com/topic/704921-help-for-this-driver/#findComment-9008330
2 minutes ago, Gombel said:
I saw that site, but i still cant find it...
Then you need to get a Xbone
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/704921-help-for-this-driver/#findComment-9008345
