So here it is, i want a PC to play latest games on meanwhile streaming it with high-end graphics with smooth fps.
I choose a 650W PSU just to future proof myself, i am not on the budget side. Now would that be enough ram tho? Streaming games requires alot of multitasking and thats why the i7 quad-core with hyperthreading, but is it enough ram?
Anyways thank you guys, any suggestions welcome.
https://linustechtips.com/topic/704748-first-ever-build-ever/
1. Your biggest sin is pairing an unlocked CPU with a motherboard that cannot overclock it. You want a Z170 motherboard to do so.
2. 16GB of RAM is ideal but $105 is a bit much, don't ya think? Considering you can pick up 16GB of 3000MHz Corsair Vengeance for cheaper.
3. Power supply isn't all that great, I would go for the EVGA SuperNOVA 550 G2 or the Corsair RM550x instead.
4. I'd opt for the Cryorig M9i or the Cryorig H7 instead of the Cooler Master Hyper 212 EVO.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/704748-first-ever-build-ever/#findComment-9006707
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($329.44 @ OutletPC)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($46.88 @ OutletPC) can get the M9i or H7 mentioned above if you wanna cheap out.
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($122.88 @ OutletPC) supports SLI and overclocking.
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($84.99 @ Newegg) faster and cheaper.
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($69.99 @ SuperBiiz) only slightly slower but much cheaper.
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($389.99 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg Marketplace)
Total: $1233.04
Generated by PCPartPicker 2016-12-10 07:55 EST-0500
https://linustechtips.com/topic/704748-first-ever-build-ever/#findComment-9006754
Wait, if this is your first build ever, don't you need a monitor and peripherals? Pairing a GTX 1070 with a 1080p display (if you have one lying around) or less is a plain waste of horsepower.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/704748-first-ever-build-ever/#findComment-9006811
Here, this includes everything you need to get started. In addition to the tower, I've included a 1440p IPS monitor, a mechanical keyboard and gaming mouse, a Windows key, and a great pair of headphones.
I've also done my best to maintain a white, blue, and black 'arctic' colour scheme, which is why I included a white case with blue LED case fans, a white mechanical keyboard with blue LED backlighting, a white mouse and headphones, and black parts for everything else. If you like the colours, this is going to look absolutely stunning.
Keep in mind that the only way to get that insane price on the Core i5 6600k is to get it from a Micro Center. The in-store price is $200, but you can get another $30 off with the purchase of a compatible motherboard. It's an enormous $60 in savings.
Keep in mind that Windows itself is free - you only need to buy an activation key, which can be had for cheap on Kinguin.com.
In my opinion, this is one of the best setups you can put together for the money.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z170M-D3H Micro ATX LGA1151 Motherboard  ($98.99 @ SuperBiiz)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: Kingston SSDNow UV400 120GB 2.5" Solid State Drive  ($41.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB Video Card  ($395.91 @ Jet)
Case: DIYPC DIY-F2-W ATX Mini Tower Case  ($38.98 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Monitor: Acer G257HU smidpx 25.0" 2560x1440 60Hz Monitor  ($233.99 @ Jet)
Keyboard: EagleTec KG011 Wired Gaming Keyboard  ($53.64 @ Amazon)
Mouse: ROCCAT Kova Wired Optical Mouse  ($46.99 @ Newegg)
Headphones: Superlux HD-681EVO  Headphones  ($45.99 @ Newegg Marketplace)
Other: Windows 10 OEM Key (Kinguin) ($25.00)
Other: Core i5 6600k (Micro Center In-Store, with motherboard bundle) ($170.00)
Total: $1351.23
Generated by PCPartPicker 2016-12-10 08:44 EST-0500
https://linustechtips.com/topic/704748-first-ever-build-ever/#findComment-9006856
