A friend of mine has the Cyberpowerpc GUA250, and this x-mas he is looking into treating himself to a new gpu. I have been looking over the internet for about an hour or so now, and I cannot find any info if these are compatible with each other. Any info could help, and for future reference, having the specs listed here would also be a bonus because there is little information about it (from what I could find).
https://linustechtips.com/topic/704546-help-with-hardware-compatibility-prebuilt-pc/
19 minutes ago, M.Yurizaki said:
It depends on the power supply. Does it have something that looks like this?
I don't know how many PCI-E cables it has, as it is my friends pc; however I do know that it currently has a NVIDIA GeForce GT 730 2gb gpu.
the gt 730 doesnt need pci-e power cables since its a low power card
It uses a 500 watt atx power supply  so you will probly also have to replace the psu but other than that he should be good
So, he does need the new PSU aswell? I also could not find if the motherboard was compatible, if that changes anything.
