Strange internet problem
No problem.. it's not a fix as such but at least you might get pointed in the right direction now with the google DNS working for you ![]()
[edit] I'm not sure about lithuania, but most european countries ISPs AFAIK use shared IP addresses and from different locations, for instance when I'm not using my VPN I can get IP addresses that say I'm from all the way across to the west of the UK.. and if I reboot I can get an IP that says I'm all the way to the easy or in London etc... this is just the localised server the ISP is using to connect you to the network. Not an actual IP address of where you live, but the WAN server if you like. I'm not an expert, and that is just my laymens knowledge of it as I see it, so please don't take offense if it was technically incorrect... but I won't mind being put right if it's incorrect too ![]()
