Forza Motorsport 6 Apex Killed PC, need help!
Okay, so my friend built a PC, specs: (i7 6700k, Asus Z170A, MSI 1070 Quicksilver, EVGA 650G2, Samsung SSD) and everything worked, he tested on Dirt 3, worked, then he tried play Forza Motorsport 6 Apex and the PC turned off, then when he tried to boot up, nothing, no lights nothing. Then he unplugged the GPU PCIE Connectors and the GPU started to light up and the fans started to spin, no signal.
Then he tried to boot up on the integrated graphics, same thing but still no signal. Does anyone know what could happen?
System: |Intel Core i5 4690K|ASRock Z97 Anniversary|2x4GB Kingston HyperX Fury 1600Mhz RAM|Sapphire Radeon RX 480 Nitro+ 4GB|Phanteks P400S TG Edition (First ever owner!)|Seagate 1TB HDD+WD Blue 620GB|Seasonic M12II-620 EVO 620W 80 Plus Bronze Modular|Cooler Master Hyper 212 EVO|
could be a number of things. you have to do the trouble shooting steps. check ram, gpu, power supply and so on.
@TheOskar57 I'm confident it isn't a malfunction due to the GPU being stressed up since I can run Forza Motorsport 6: Apex at above 40 FPS with my weak 920M. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
The power supply is fried.
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Maybe, but you can't 100% say thats what it is.
Just now, 3DGamerOnSteam said:
Maybe, but you can 100% say thats what it is.
I know... But the issue looks like the PSU is dying... @TheOskar57 Try using another PSU, and if it works, then the PSU should be RMA'd
He doesn't have another PSU
Idk then, he can get a cheap EVGA 430W PSU to test his system with... It is only $30...
