So, on my friends PC, everything turns on but monitors don't display anything.
HeI took it to a PC place and they took out the ram, and then reseated the ram, and it booted fine. Restarted PC and it did the same thing.
They think it's a mobo issue but apparently they cant "test" it. Last thing i've thought of it resetting CMOS, not exactly sure what it does though.
CPU : i7 4790K // GPU: MSI 980Ti 6G // CPU Cooler: LEPA AquaChanger 240 // MOBO: Gigabyte GA-Z97X-SLI // RAM: 16GB HyperX Fury @ 1866 //    Case & PSU // Fractal Define S & EVGA 750W
https://linustechtips.com/topic/703983-mobo-problems/
Just now, goodtofufriday said:
Need a better symptom description than "doesnt boot properly"
Sorry. Monitors don't display anything, but everything powers on.
https://linustechtips.com/topic/703983-mobo-problems/#findComment-8998349
Does it have a graphics card? Have you tried a different power supply?
Yes it has a gfx card, have tried another one in it and same problem. The Mobo doesnt have any display ports.
Different power supply, I have not... But I can try.
https://linustechtips.com/topic/703983-mobo-problems/#findComment-8998394
Do so and report back. I doubt the ram re-seat did anything. if the psu is on the fritz it could work intermittently.
CPU: Amd 7800X3D | GPU: AMD 7900XTX
https://linustechtips.com/topic/703983-mobo-problems/#findComment-8998406
Any other way to contact you?
Steam?
https://linustechtips.com/topic/703983-mobo-problems/#findComment-8998418
