Need help in finding a precision scale
Hi so I have a project due the 14th of december, and for the thing I am doing I need a precision scale (Measuring amount of dust) Does anyone know of any good ones under 20 (30 if needed) I need it shipped by the 12th max so please link reliable sources.
Also anyone know any other way I could measure dust? I'm not trying to measure dust levels of a room, I have 5 little sheets of colored material and I'm going to leave the material in for a few days (Really dusty house speeds up the process xD ) and I need a precise way of measuring it. Also if needed the sheets are around 5*3-4 inches
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/703596-need-help-in-finding-a-precision-scale/
20-30 potatoes? What currency.
Do you know approximately how much the dust will weigh, or how presice you need it to be?
To get one that will read into the hundredths of grams you want a very good scientific scale with a cover because air pressure changes will cause it to change. They will be very expensive as well.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
Dollars.
Well is there any cheap way to measure dust? It doesn't need to be that accurate as long as you can tell the difference.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://www.amazon.com/s/ref=nb_sb_ss_c_1_20?url=search-alias%3Daps&field-keywords=scales+digital+0.01gram&sprefix=scales+digital+0.01g%2Caps%2C263&crid=1FMC3GV6FIN06
Basically all these have a precision of 0.01g, no idea how accurate they are.
If none of these will do, is there a (erm) 'paraphenalia' shop near you ?
They may well have something that will do.
Edit :-
To cope with higher than this precision you would need proper scientific scales which will indeed, as mentioned above, need a cover to stop air currents/your breath etc altering the reading these can go into the thousands for decent ones obviouslly no good for a school project.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
1 minute ago, SCHISCHKA said:
if i were to measure dust i would collect it in a water filter
What do you mean?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
I'm a precision rifle shooter, and i need a scale that resolves to the kernel of powder. 0.02 grains is considered quite accurate resolution.
the problem you're going to find in those pocket scales is drift. it will fall out of calibration quickly and will often not stabilize. I had one and will never ever buy one let alone suggest one.
I use an A&D FXi i think it's a 320. not cheap. the one previous to this one was an Acculab.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Just now, SCHISCHKA said:
pump air through water
I'm not trying to collect dust levels of the room, I need to measure the amount of dust on a 5*3-4 in. piece of colored paper
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Just now, Velvet Revolver said:
Canadian
Australia
US
NZ
or any other of the 10 currencies that use the dollar
https://en.wikipedia.org/wiki/Dollar
US
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
1 hour ago, vinyldash303 said:
If youre in High School im sure you could borrow one from the science deprtment
Thats actually a pretty good idea... Thank you!
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
