A friend of mine is going to be getting into PC gamig and he is on a tight budget, so the
Cheaper the better, but he has no more than $400. What's the best PC he can build
For 1080p medium settings? He's said he doesn't need ultra , just a smooth medium in games
Like battlefield 1, 4, watch dogs 2, the division. Thanks for any help
https://linustechtips.com/topic/703169-battlefield-1-build-help/
medium? Boy, if anyone can build a computer for 400$ that has a decent external gpu that can run BF1 1080p at medium settings (i guess its a well optimized game, but i dunno tough), without using refurbished parts, is a freaking god xD.
Groomlake Authority
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987590
external gpu?
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987595
I would tell him to either go used for a few parts (cpu, gpu, mobo) or if he wants all new then to go with this. https://pcpartpicker.com/list/3jnD7h
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987603
os/monitor/peripherals?
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987606
Just now, g12601 said:
Dual core, terrible idea. 4 cores is basically the minimum.
the g4400 is the only cpu for this price range that has the single core power to run games at all.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987618
If he needs any of that then he will need to wait for an extra 100-150$ before even thinking about building something.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987635
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($104.99 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($39.98 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($41.98 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: Zotac GeForce GTX 1050 2GB Mini Video Card  ($109.99 @ SuperBiiz) a 1050ti will put him $10 over budget, but try to convince him to save up for it.
Case: Rosewill FBM-05 MicroATX Mini Tower Case  ($9.99 @ Newegg)
Power Supply: SeaSonic 300W 80+ Bronze Certified ATX Power Supply  ($33.98 @ Newegg)
Total: $380.90
Generated by PCPartPicker 2016-12-06 19:57 EST-0500
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987636
Total: $380.90
That actually looks pretty good and if he can get the 1050 ti then that will be geared for 1080 high.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987657
4 minutes ago, AniJan said:
With $400, I don't think you'll get too much of a good experience.
I mean, you can get decent FPS at medium settings.
herman's build that is listed above will provide a pretty good experience at 1080p.
8086k Winner BABY!!
Main rig
GFs System
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8987726
Take this build.
I have a i3 2120,  16gb ddr3, gtx 1050ti and I can play bf1 at medium/high with 60fps. My i3 2120 actually bottlenecks the gpu, but not by much. So an i3 6100 will be great
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/703169-battlefield-1-build-help/#findComment-8988080
