Would it work or not?
8 members have voted
  1. 1. Would it work or not?
    • Yes
    • No
      3
    • Banana
      5
I was wondering, could I plug the USB cable from the Blue Yeti Pro into a female USB to male 3.5mm audio jack connector and plug it into the audio jack port on my sound card? Would that work or not? Because I think it needs to be plugged into a USB port for the power but maybe the 3.5mm audio jack port would be suffice? Thanks!
https://linustechtips.com/topic/702898-blue-yeti-pro-question/
It does need to be plugged into a USB port for power and audio transfer so I don't think just a 3.5mm jack would provide enough.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/702898-blue-yeti-pro-question/#findComment-8984315
Wait you spent $230 on a USB Mic?
If you want to do this should've gone XLR.
https://linustechtips.com/topic/702898-blue-yeti-pro-question/#findComment-8984327
1 minute ago, Deyarn said:
Can I use XLR to 3.5mm jack connector for it with the usb to usb cable to a usb port for power? Is this retarded or no?
Im pretty sure Yeti pro has no XLr support so no.
https://linustechtips.com/topic/702898-blue-yeti-pro-question/#findComment-8984724
