Best sub $40 case?
Go to solution Solved by Energycore,
1 minute ago, ShadySocks said:
I don't see the clear superiority of the CM, or the Corsair Spec 01 over the stryker. I do have a modular PSU.
Well the stryker looks more cheaply made, has sharp edges that might damage your cables, but you're right it should be OK
I have assembled a list of good cases, but can't decide. Here it is:
Cooler Master HAF 912 $40 Rosewill CHALLENGER S $20 Rosewill Stryker M $25 Rosewill GUNGNIR $30
Should I go with one of the cheaper cases, or get the CM. It will cut into my CPU budget, so I have to decide well. :(
https://linustechtips.com/topic/702698-best-sub-40-case/
http://pcpartpicker.com/product/fXw323/nzxt-case-s210001
ATX Mid tower or Micro ATX?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8981961
Out of those four, the HAF 912 is the only one I'd even consider.
Or this thermaltake
https://pcpartpicker.com/product/FzKhP6/thermaltake-case-ca1c100m1nn00
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8981989
Deepcool Tesseract or Corsair SPEC 01
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8981999
Or this thermaltake
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982020
Computer Specs:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982032
I am probably going to go with the CM. You're right. Because of my low budget, I have been cheaping out on a lot stuff I buy, and many of those bug me daily. for $20 more, it is probably going to be worth it.
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982055
As long as you don't cheap out on the Power Supply (look, an EVGA 500W 80+ is fine, but don't get no Logisys), you're fine ;)
Computer Specs:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982060
I cheaped out. I got a 750w modular PSU for $35 :P
Return it and get a $35 EVGA 500W
Not even joking.
Computer Specs:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982090
Ahhh you're probably OK
I got worried because most $35 750W units are actually really bad 400W units that lie about their rated power output.
Got me scared for a moment there :P
Computer Specs:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982100
:D i was super scared, 'PSU Quality Enthusiast'
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982107
Haha I care a lot. Well happy computing (and if you're gonna do a really high-end build with an i7 and crossfire 490s, don't use that HIVE :P)
Computer Specs:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8982122
That Hive is OK, especially for $35 I'd say its probably pretty good, although a 500B or CX450M would probably be less crap lol
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/702698-best-sub-40-case/#findComment-8985797
