hello im trying to list candidate 2's total job history and thier current job placement.
my faulty current sql code
SELECT j.Candidate_ID,
             j.Job_tittle,
             p.Candidate_ID,
              p.Job_tittle
FROM Job_History j,
            Placement p
WHERE j.Candidate_ID = p.Candidate_ID
              and j.Candidate_ID = 2
               and
https://linustechtips.com/topic/702647-sql-help/
29 minutes ago, SCHISCHKA said:
it is not complete and you prob have to put '2' with the appropriate quote marks
               and
Aren't quotation marks for strings?
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
https://linustechtips.com/topic/702647-sql-help/#findComment-8981387
               j.Job_tittle,
                p.Candidate_ID,
                 p.Job_tittle
FROM Job_History j,
            Placement p
              and (j.Candidate_ID = '2')
gives me an error
https://linustechtips.com/topic/702647-sql-help/#findComment-8981477
4 minutes ago, SCHISCHKA said:
depends on the database engine and the data type; thats why i say probably
its accses and its an auto number
after correcting the spelling it outputs an error data type error mismatch i dont understand what is the data mismatch
https://linustechtips.com/topic/702647-sql-help/#findComment-8981661
It probably has to do with this
j.Candidate_ID = 2
vs
Use the correct data type for the column Candidate_ID
https://linustechtips.com/topic/702647-sql-help/#findComment-8981740
