i have a hyper beast pre ordered and have a motherboard, PSU, and CPU picked out (MSI 970 AM3+ Pro Carbon) + (AMD FX-9590) i have a cx 430 on hand, but would like an RM850X. i planb for watercooling and possibly an R9 fury but cant find a good block for it i would lik eall EKWB blocks and res + pump. I cannot find any good ram that isnt already lit because the motherboard is rgb i dont want to be stuck with one color on the ram and none of the ones i want are unlit can i turn the leds of on the corsair vengeance led series?
open to any suggestions for specs.
https://linustechtips.com/topic/702217-h440-hyper-beast-build/
please not a 9590
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8975993
20 minutes ago, XPS630i said:
whats wrong with the 9590?
it is just horrible. for around $200, just go intel i5. the 9590 uses too much power, REQUIRES water cooling, and is honestly not good. The factory 4.7 GHz is unstable and lots of people had to underclock just to use the system. Please save yourself by going i5.
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976115
i dont want an intel system this time around im staying amd
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976122
It's basically just a heavily overclocked 8350, and sucks power like you wouldn't believe. I believe it's north of 225w. It'll also get spanked by an i7, and likely even an i5.
I don't think your 430w PSU would stand a chance.
There's loads of good non lit RAM. RAM is RAM. Go with the cheapest stick in the color you want.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976131
then wait for zen. do not go FX 9590 or any previous AMD generations. See what Zen has to offer first.
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976175
can you turn the led off on any of them?
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976189
Nonlit. Non. Meaning no LED.
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976284
Just now, XPS630i said:
is there a way to turn them off on the vengeance led or dominators? i like those two but dont want the lights all that much. and im not stupid thanks.
No idea.
I didn't say you were, however you should have been able to figure it out on your own without me having to emphasis it, yeah? ;)
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976302
Just now, dizmo said:
No idea.
you really didn't need to emphasize anything i got it i am interested in those two and asked if i can turn the leds off
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976315
I said this.
You said this.
How am I supposed to know you're talking about the other two, when you stated that in response to what I said?
If you were talking about the two you mentioned, it would be either, not any.
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976335
1 minute ago, dizmo said:
I said this.
You said this.
k? sorry for not wording it right i remember why i quit using the forum before now
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976347
xD
https://linustechtips.com/topic/702217-h440-hyper-beast-build/#findComment-8976533
