New Asus Laptop Audio Problem
Go to solution Solved by MadmanGraphics,
10 minutes ago, RadiatingLight said:
Most likely it's physically broken
I really hope not but if that is the case then that really sucks...
10 minutes ago, Pomfinator said:
Looks like it's a physical issue.  You're sure it doesn't work? As in if you blast it you don't feel any air vibration on the grille at all? If so, it's probably a physical issue and you should call support to see if they can help you.
I muted the right speaker and I get nothing at all, not even a vibration.
9 minutes ago, Moist_Sock said:
Open it up and see if the driver[s?] still works. I highly doubt its a driver issue.
I really want to open it up and take a look but it would void my warranty.
Thank you all for the immediate responses!
It looks like I need to have it serviced to avoid voiding my warranty. This sucks a lot seeing how I just got this laptop just this last September.
Good day everyone!
I have had this laptop for almost 3 months now, and just this morning I noticed my left internal speaker is not working at all. It is not a balance issue since both sides are at 100%.
I googled and found that it may be my Realtek HD Audio driver is out of date. I downloaded the new driver from the Realtek website and after launching the application it had uninstalled and then installed the new drivers after 2 restarts.
I went to play something on Youtube and my left speaker is still out. Uninstalled my audio drivers manually and installed them and still nothing.
I have no idea what to do and I hope there is nothing physically wrong with my speaker.
Any help on how to fix my issue would be awesome.
https://linustechtips.com/topic/702170-new-asus-laptop-audio-problem/
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
