Hey
I have an issue with my system audio. I don't know if Skype causes it but I notice it during Skype sessions.
What happens is my audio just cuts off for about a second or so, this meaning that I recive no audio into my headphones and the guys in Skype said they cant hear me during this time as well. Once the second or so is over I can hear the audio that I missed and this happens once every 20sec with variations.
Specs:
Focusrite Scarlett Solo 2nd Gen > Sennheiser HD 380 Pro as headphones and MXL V67 MD1 from Massdrop as mic
  • CPU
    AMD FX-8350
  • GPU
    MSI Gaming GTX 770 2GB (Overclocked)
  • RAM
    Kingston HyperX Beast 1600 MHz 8GB Dual-Channel
  • Motherboard
    Asrock Fatal1ty 990FX Killer
  • Case
    Corsair Air 540
  • Storage
    WD Black 1TB HDD
  • PSU
    Corsair CX750M
CPU is at like 50C and GPU at 70 C
Wtf is happening to my audio and how do I stop it.
Halp pls.
Send help
https://linustechtips.com/topic/701592-system-audio-clipping/
Had this issue as well, you need to go into your BIOS and turn off all power saving and CPU Idle settings, otherwise your DPC is too high for your computer to seamlessly "stream" data to your Audio device
I would check using DPC Checker located here ---> http://www.thesycon.de/eng/latency_check.shtml
Also don't forget to update your Audio Drivers manually
https://linustechtips.com/topic/701592-system-audio-clipping/#findComment-8969194
@Palden @syn2112
Okay so DPC Checker showed me that the latency was constantly in the red and it peaked when the audio clipped and went back down to yellow-ish for awhile. I went into BIOS but haven't found any power saving settings per se.
In the bios I found something called Cool 'n 'Quiet and Core C6 Mode. Is it safe to disable these? And on a side note should I use the fast boot or ultra fast boot functionality.
Send help
https://linustechtips.com/topic/701592-system-audio-clipping/#findComment-8971544
