How do I fix dead USB ports?
1 minute ago, themctipers said:(Sorry if this is the wrong section)
So yesterday I plugged in my G502 into one of my USB ports, and it appears that it has burnt that USB port out. I've plugged it into another one, and it burnt out again. I had learned from my mistake and now its plugged into a USB 1.1 port in case if it burns that (I don't really care about those ports, its USB 1.1 and most of my devices requires 2.0 speeds, and I have 4 1.1 ports)
Is there a way to 'repair' these ports? It has burnt out the ports on the motherboard itself, not using the USB headers. I only have 4 ports left, since the other 2 are broke. (Yes, I need ~5 devices to be plugged in almost all the time)
I have turned down my machine and turned it back on twice (power down via windows, switched the PSU switch, pressed the power button twice, waited ten seconds, bootup again)
I have also tried multiple devices (USB, mouse receiver, printer) and the ports are still dead.
Any help would be appreciated, I don't like the hassel of unplugging a device when I want to plug in a usb.
If it's directly on the MOBO you cannot do anything. Get an RMA done
