Hey all,
I'm planning on upgrading my motherboard, CPU and RAM... Currently I can muster about $700 and I'm thinking of....
Z170A for Motherboard:https://www.amazon.com/MSI-Performance-Gaming-Z170A-Motherboard/dp/B01BIUW9PO/ref=sr_1_5?ie=UTF8&qid=1480766259&sr=8-5&keywords=Z170-PRO-GAMING&th=1
Intel Core i7 6700k for CPU: https://www.amazon.com/Intel-Unlocked-Skylake-Processor-BX80662I76700K/dp/B012M8LXQW/ref=sr_1_1?s=pc&ie=UTF8&qid=1480766383&sr=1-1&keywords=intel+i7+6700k
16gb of DDR4 3000mhz for RAM: https://www.amazon.com/Patriot-Memory-3000MHz-Channel-PV416G300C6K/dp/B0157UQ5A6/ref=sr_1_2?ie=UTF8&qid=1480766449&sr=8-2&keywords=Patriot+16GB+Viper+4+DDR4
The purpose of this rig is mostly for gaming, perhaps along with some development and rendering at times.
At the moment I'm using Zotac GTX 1060 3gb, a 500W powersource and a BenQ XL2411Z 1080p@144hz monitor (which I assume should be fine with only 3gb of Vram).
Should I go with this upgrade or tune down it a bit and sell my 1060 then buy a 1070? I'm living in Seattle - WA, just moved here and don't know of any good location for building a pc so I'm just aiming my price at what amazon has at the moment.
Reason why I need this upgrade: my current motherboard is B85 and it's pretty old, gave me a lot of crashes as well.
Also are there places to sell your old computer parts in Seattle?
https://linustechtips.com/topic/701294-budget-rig-upgrade-need-help/
2 minutes ago, Jed M said:
What is your 500W PSU?  And tbh, you should sell your 1060 3GB, get an i5-6600k instead of that i7, and some cheaper lower latency RAM along with a 1070 GPU.
I'm using a Corsair CX500 I believe.
Is it worth it though? I'm not gaming on 4k and I don't know how much a i5-6600k would be a drop compares to a i7-6700k also with a gtx 1060 and a 1070.
i5-6600k + 1070 is good for 1080P and 1440P. i5-6600k is all you need for gaming really.
2 minutes ago, Valhari said:
Alright, thanks for your help. I'll look into it.
Something to note;
Motherboard choice does not affect performance to any significant degree. Therefore choice should be dictated by feature set. Beyond that, it's all e-peen and vanity.
In other words, where bang for your buck is concerned, find the cheapest motherboard with the necessary features you require.
My 2c
20 hours ago, Valhari said:
By the way, any specific recommendations for RAM? I think 16gb and about 3000mhz should be fine
RAM frequency does not matter in gaming. 1333MHz vs 3000MHz would have 5 FPS difference AT MOST. Just get RAM with a lower CAS latency (15 or lower).
