I have a Magni/Modi2 setup and I would like to put an audio switch box in between them to have an output for my active studio monitors.
            Amp
Dac>Switch Box>Monitors
How could I make this work? What switch box should I use. It needs to have one input and two outputs.
https://linustechtips.com/topic/701199-splitter-for-headphonesspeakers/
40 minutes ago, Tuna Terrorist said:
-snip-
This seems to be the closest I've found with one input and multiple RCA outputs. Hard to say the quality though and it's a splitter, not a switch. Do your Magni/Modi have optical/SPDIF? Monoprice has a 1 in, 2 out optical splitter that would seem to be the better way to go if your hardware supports it. What's your budget like? A small audio mixer might work out better for you (something like this). You could put your DAC to an input channel (with that mixer, I'd get RCA > 1/4" adapters/cables and run the DAC to Line 3/4), headphone out to headphone amp then main out to your monitors.
ψ ︿_____︿_ψ_
  • 3 weeks later...
