CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($49.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($39.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($249.99 @ Jet)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($38.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($89.00 @ Amazon)
Total: $712.82
Generated by PCPartPicker 2016-12-02 12:43 EST-0500
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/700908-help/#findComment-8961897
Total: $712.82
Hmm.
What if the budget is increased to $750?
Would it make any difference?
https://linustechtips.com/topic/700908-help/#findComment-8961914
1 minute ago, AniJan said:
Hmm.
I'd throw in a 120gb SSD, maybe get a nicer case/psu. But neither of the latter are really necessary. The next big upgrade would be to a 1070 (and a 6700k).
PSU Tier List | CoC
https://linustechtips.com/topic/700908-help/#findComment-8961919
Just now, AniJan said:
How about more ram?
8gb is probably more than enough. But you could add another 8gb stick.
PSU Tier List | CoC
https://linustechtips.com/topic/700908-help/#findComment-8961926
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($191.89 @ OutletPC)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.98 @ Newegg)
Memory: G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: ADATA Premier SP550 120GB 2.5" Solid State Drive  ($38.49 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Total: $739.10
Generated by PCPartPicker 2016-12-02 12:57 EST-0500
you can get a OS off of /r/microsoftwareswap or kinguin for like $25-30
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/700908-help/#findComment-8961956
Total: $739.10
Hmm.
Seems good to me, but that's not my choice to decide.
Thanks guys, and please continue to suggest more if you can.
https://linustechtips.com/topic/700908-help/#findComment-8963042
