Not sure wheteher this should be in psu or mobo section, so please feel free to move it, thanks mod
Hi i was building my rig today and was connectin the 24 pin from psu to motherboard. i have tried as hard as i can to push, it wont snap into place. it has a gap about the thickness of nails.
https://imgur.com/a/TKNWj
any advice? and is it safe to leave it like this?
Thanks for looking
https://linustechtips.com/topic/700786-24-pin-problem/
Also make sure both connectors are clean and fine - no foreign objects blocking, no bent pins etc.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/700786-24-pin-problem/#findComment-8960664
The tiny 4 pin segment slides on one side into the larger 20 pin connector , or the other way around. Don't try to push them in the 24 pin connector separately.
Basically one of the segments has some extra plastic which forms a sort of channel in which the other segment slides and stays very fit with the other segment.
When inserting the full connector, put your fingers under the socket on the motherboard, so the board won't flex too much when you push the connector in the socket.
https://linustechtips.com/topic/700786-24-pin-problem/#findComment-8960683
I had this happen to my friend. We tried everything but in the end nothing worked and it stayed that way. If everything boots and gets power fine, don't worry about it.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/700786-24-pin-problem/#findComment-8960715
yes i did put them together then push forward.  Just now i unplug it (which was pretty tight), and just plug the 4 pin by ot self and it turn out pretty smooth, but however the 20 pin was pretty hard to plug in
https://linustechtips.com/topic/700786-24-pin-problem/#findComment-8960776
