best wireless gaming mice?
Go to solution Solved by JORDANonPC,
too expensive would probably be like over $100
ah right g700s then I have the g700 and it's brilliant wired and wireless I can't tell any difference in latency, plus you always have the option for wired and the buttons come in handy for any genre of game
wireless, gaming and cheap do not go well together you need to sacrifice one of those things sadly
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/70071-best-wireless-gaming-mice/#findComment-960269
You can also pick up a G700 for around $60-$70. The G700s only has a little nicer clicks and a rubber coating, I own both and it may not be worth the extra money. If you want to save a little, the G700 is a great option.
https://linustechtips.com/topic/70071-best-wireless-gaming-mice/#findComment-960279
https://linustechtips.com/topic/70071-best-wireless-gaming-mice/#findComment-960286
