I have been looking to get a new tower for a good while but having been a console gamer for a good while, I need a bit of help gettting sorted with some ideas for spec.
What I had in mind was as follows:
i5 6600k
8gb ddr4 hyperx fury
6gb 1060
Asus z170 Pro Gaming Aura
120gb Kingston ssd
2TB HDD
Corsair 650w CS Mod 80 plus gold
Fractal Define S
This is the kind of money I'm looking at, around the £1100 not including monitor (which I haven't got a clue about) and keyboard and mouse.
Any help would be greatly appreciated.
Cheers
https://linustechtips.com/topic/699484-first-build/
If you're in the UK, try looking at CEX for your CPU and RAM. You'll get a 2 year warranty even though they're used, and they're most importantly cheap.
Like, you can get a 6700 for £10 more than a 6500K
https://uk.webuy.com/product.php?sku=SCPUINTI56600KA#.WD4HZFy8p3d
https://uk.webuy.com/product.php?sku=SCPUINTI76700#.WD4HSly8p3c
8GB stick of DDR4 2400 for £25
https://uk.webuy.com/product.php?sku=SMEM8G2400#.WD4HmFy8p3c
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/699484-first-build/#findComment-8946212
Just keep in mind you won't get a stock cooler with your CPU, so you'll need to get a aftermarket one (recommended anyway) and what brand RAM you'll get is a lucky dip.
https://linustechtips.com/topic/699484-first-build/#findComment-8946221
I might bump that up to 16GB of ram personally (2*8 GB DIMMS). I had a very similar setup (6600K, that board but no lighting, and a 980 instead of a 1060), and I feel that RAM configuration was ideal
I also have the aura board now, and can say I like it, nice choice!
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/699484-first-build/#findComment-8946224
I was looking at one of the lower h series coolers or one of the big coolermaster ones but I'm not sure water cooling or traditional
https://linustechtips.com/topic/699484-first-build/#findComment-8946696
Yeah ram was a sticky bit for me but I was going to get 8 (2x4) and further down the road get another kit because I think it's 8 dimms on the aura? Just looks badass with 4 sticks I would think
https://linustechtips.com/topic/699484-first-build/#findComment-8946705
For a 6700, a 120mm AIO would do pretty well. Got one in my 6700k non-oc pc. They go for about £50 on amazon.
For aesthetics, I'd go for a beefy LP cooler or a AIO.
https://linustechtips.com/topic/699484-first-build/#findComment-8946706
I am in the U.K. but hadn't started looking for parts yet, but I'll definitely have a look at cex to see.
https://linustechtips.com/topic/699484-first-build/#findComment-8946717
https://www.amazon.co.uk/RAIJINTEK-Corporation-0R100004-raijintek-0R100004 Fan/dp/B00IAPTBCK/ref=sr_1_1?ie=UTF8&qid=1480466710&sr=8-1&keywords=raijintek+pallas
If you're into red/white, this cooler will be enough for a 6700 (not OC'd K) and looks pretty BA imo.
https://linustechtips.com/topic/699484-first-build/#findComment-8946752
I would say you would do fine with 550W, the 1060 is really efficient.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/699484-first-build/#findComment-8948813
no, the board only has 4 DIMMS, since this is a skylake build, it only supports up to 4
https://linustechtips.com/topic/699484-first-build/#findComment-8948855
1 hour ago, HelpMePleaseThanks said:
Just went for 650 because I could, future proofing and all that, made sense in my head
For what? Unless you are getting two 1060s (you can't no SLI) you will never need 650Ws.
https://linustechtips.com/topic/699484-first-build/#findComment-8952666
7 hours ago, HelpMePleaseThanks said:
Ahh well then, still should look pretty beast with 4 sticks ?
I wouldn't use 4 initially, I would use 2 because you still get the speed benefit of dual channel, but leave the ability to double your capacity down the road.
https://linustechtips.com/topic/699484-first-build/#findComment-8954134
