CPU running unusually hot
Go to solution Solved by msterforks,
So I figured out the problem. Yes, I have an intel stock cooler. Yes, it is still spinning. Thermal paste is probably there too (although I never verified this). My PC "mysteriously" reverted back to normal temperatures. Turns out my trash bag hung in a way that blocked a vent hole on the side of my PC -_-;;
Thanks for the help guys.
When I booted up my PC this morning, I noticed that I was getting constant frame drops on a game that I play regularly. I suspected that my CPU was being thermal throttled, and sure enough, RealTemp shows me exactly that.
I had this problem once before, but it mysteriously disappeared after I let my computer sit for half an hour. However, this time I let my computer sit idle for about an hour and a half, and the temperatures were still in the 50s (the minimum row in the screenshot). I'm not sure why this happened and what I should do to fix it. I plan on cracking open my computer either today or tomorrow. Is there anything I should look for while I'm in there?
EDIT: The screenshot captured the exact moment the load decided to spike up. Usually it sits around 25% with occasional jumps to the 50s or 60s.
https://linustechtips.com/topic/699337-cpu-running-unusually-hot/
Cooler? CPU?
CPU: I7 5820K@4.0Ghz | Mobo: ASRock X99 Extreme4 | Ram: 4 x 4Gb G.Skill Tridentz@3200Mhz | GPU: XFX 390x | Cooling: Corsair H115i | PSU: Corsair RMX 850x | Storage: Samsung 250Gb 850 EVO + 2tb Seagate HDD | Case: Inwin 805 | Keyboard: Tesoro Gram Spectrum | Mouse: Tesoro Gram H3L | Mousepad: Corsair MM800 RGB  | OS: Windows 10
20 minutes ago, Beeeyeee said:
Whats your CPU and cooler?
first thing is I would reseat the CPU and remount the cooler with new thermal paste. sometimes it can go bad if its crappy. aside from that a new cooler is all you can do:)
I bought the processor 5 years ago and I honestly can't remember. It's probably the stock intel cooler. The CPU is the i7-2600 (non K) as shown in the screenshot.
okay do what I said and tell me what happens:)
2 minutes ago, pwn_intended said:
Check that the fan on the cooler is spinning and that it isn't totally clogged with dust!
I clean my computer regularly (at least twice a year). I'll check if there's an unusual amount of dust and grit though.
The fan spinning is key too. Had a friend whose CPU died because he didn't realize that his CPU fan was dead and he didn't monitor his temps regularly.
When in doubt, re-format.
