I think I might have messed up on my build.
Solved by typographie,
The video device that you plug your monitor into will be the device that renders to that monitor. If you have a video card and you mean to use it for gaming, you must plug your monitor into that card. If you plug it into your motherboard, you'd be using the CPU's integrated video hardware, which is mostly unsuitable for gaming.
For future reference, it's fairly easy to find adapters for most monitor ports. As long as you are going from one type of digital connection to another, a simple DVI/HDMI/DisplayPort adapter can be found for $5 or so. Your video card may even have come with one in the box. It gets a little more complicated if you need to go from analog (VGA) to digital, but adapters exist for that as well.
