3 minutes ago, GalacticRuler said:
Please put this into PCPartPicker.
PCPartPicker part list: https://pcpartpicker.com/list/mx2yqk
Price breakdown by merchant: https://pcpartpicker.com/list/mx2yqk/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($66.49 @ OutletPC)
Motherboard: Asus H81M-A Micro ATX LGA1150 Motherboard  ($55.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($57.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: Zotac GeForce GTX 1050 2GB Mini Video Card  ($99.99 @ Newegg)
Case: Rosewill FBM-01 MicroATX Mini Tower Case  ($12.99 @ Newegg)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($33.99 @ B&H)
Total: $375.32
Generated by PCPartPicker 2016-11-29 00:27 EST-0500
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941760
2 minutes ago, DaShesano said:
Pretty good, however you may want to get a beefier CPU cooler like a hyper 212 evo and a Z series board to do some overclocking on that CPU to get a bit more performance out of it.
Besides that its a great build
Z series boards aren't optimized for the pentium g3258 personally every time I've used them the they performed less than when I used h81 boards for overclocking
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941769
Ah, just don't use stock cooling if you plan to overclock.
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941770
Obviously I meant with the pentium g3258
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941774
If what you want is overclocking, a locked Athlon X4 845 is guaranteed to be more fun because it will have you messing with the BCLK (you can do that on AMD CPUs of this gen). It's also a more capable gaming chip.
CPU: AMD Athlon X4 845 3.5GHz Quad-Core Processor  ($67.99 @ Newegg)
Motherboard: ASRock FM2A88M PRO3+ Micro ATX FM2+ Motherboard  ($51.98 @ Newegg)
Memory: Mushkin Stealth 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Jet)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($34.99 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.40 @ SuperBiiz)
Total: $361.33
Generated by PCPartPicker 2016-11-29 00:37 EST-0500
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941805
I'd personally have gone with an i3 at the minimum for gaming these days. Too many games will use at least a dual core these days and that'll leave you almost nothing for your OS to use in the background. :P
You can find an i3 4150 for pretty cheap around online, ebay and the like. It's what I'd do... >.>;
S.K.Y.N.E.T. v4.3
AMD Ryzen 7 5800X3D | 64GB DDR4 3200 | 12GB RX 6700XT |   Twin 24" Pixio PX248 Prime 1080p 144Hz Displays | 256GB Sabrent NVMe (OS) | 500GB Samsung 840 Pro #1 | 500GB Samsung 840 Pro #2 | 2TB Samsung 860 Evo1TB Western Digital NVMe | 2TB Sabrent NVMe | Intel Wireless-AC 9260
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941818
Total: $361.33
Ew no. AMD < Intel here. I'd never try to game on anything branded 'Athlon' right now. It's like the new Sempron. It's just not what it used to be.
S.K.Y.N.E.T. v4.3
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941824
Source?
I can tell you this: Multiple games today will tank performance or flat out refuse to boot (thanks to Ubisoft for that one) on a CPU that can only handle two threads. These Pentiums aren't gaming CPUs anymore. That and the Athlon will do just fine paired with a GTX 1050.
Computer Specs:
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941828
Just now, Energycore said:
Source?
Which games won't start exactly? FailCry 4 and FailharderCry Primal? LOL like anyone cares about those. AMD uses a platform from 2012 and Intel uses one from 2015+ right now. There's NO reason to bother using AMD for anything. You limit yourself so heavily by going with AMD. At least with Intel as he is, he could snag an i7 and upgrade his GPU without the fear of bottlenecking. Only the most heavily threaded Triple-A games will use the top FX chips too. BF1 works fine, but that's only because it can use the full CPU.
The number of games that don't work aren't the games that are actually PLAYED today, and that needs to be the point here. More cores doesn't mean it's a better CPU. If it did, AMD wouldn't be bankrupt right now and betting it all on Zen now would they?
S.K.Y.N.E.T. v4.3
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8941837
5 hours ago, Strike105X said:
I guess nobody plays titanfall 2 or any of the forza games on pc either... Yes those do not work on anything that doesn't have 4 threads.
so should I get a amd athlon x4 860 or x4 845 ? there roughlty the same price for me right now
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8943152
The 860K is an easier overclocking experience because you can play with its multiplier. Also if you're gonna OC, don't cheap out on the motherboard lest you pull too much power and set its VRMs on fire (if it's got a heatsink over the power delivery area, it will do fine). If you don't like the stock cooler, the best aftermarket I can recommend for you is a Deepcool Gammaxx 400. It should go for the equivalent of $25, and is amazing performance for the money.
Computer Specs:
https://linustechtips.com/topic/699070-double-check-my-build/#findComment-8944059
