Motherboard: B85 pro gamer
Processor: intel i5 4440
Psu:cx 550
Gpu:asus strix gtx 960
Can you help me out with CPU led issue in Asus motherboard
After pressing start button only cpu led lights up, cpu fan run constantly,no beeps.
But sometime it works normally.
I have  tried mantling and dismantling processor several time
But I am still facing the CPU led problem
If you can help us please reply
https://linustechtips.com/topic/699048-asus-cpu-led-on-issue/
5 minutes ago, Wolther said:
Do you have your ram installed? I can't tell with the picture at that angle
if so, check all of your psu cables leading to the mobo
Yes it is installed!!
I have checked all the psu cable that should be connected to mobo are connected properly
https://linustechtips.com/topic/699048-asus-cpu-led-on-issue/#findComment-8941519
Check for shorts.
This is going to be a pain, but take out your build from the case and place it on carboard (try your motherboard box) and see if it'll run
Also.. check for bent pins
https://linustechtips.com/topic/699048-asus-cpu-led-on-issue/#findComment-8941542
