I want to get a monitor. I want 144hz and 1080p or 1440p. I also want G sync. The problem is I don't exactly want to spend 800 dollars on the monitor, unless it is necessary. I want a 27 inch monitor. Also if you guys could tell me if I should spend less (happy) and get a 1080p monitor or spend more and get a 1440p monitor (sad for money loss) is it worth it??? Thanks
https://linustechtips.com/topic/698994-help/
its really up to you for the resolution thing, so can you please give me a rundown of your pc parts so I know if you can handle 1440p
PCPartPicker part list: https://pcpartpicker.com/list/Hn42tJ
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  @4.8 gHz
CPU Cooler: Corsair - H115i 104.7 CFM Liquid CPU Cooler
Thermal Compound: Thermal Grizzly - Kryonaut 1g Thermal Paste
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory
Storage: Samsung - 840 EVO 250GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Wireless Network Adapter: TP-Link - TL-WDN4800 PCI-Express x1 802.11a/b/g/n Wi-Fi Adapter
Monitor: Asus - VC279H 27.0" 1920x1080 60Hz Monitor
Keyboard: AZIO - MGK1 Wired Gaming Keyboard
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse
Headphones: Audio-Technica - ATH-M50  Headphones
https://linustechtips.com/topic/698994-help/#findComment-8940940
Just now, Blue_Meanie said:
EVGA FTW 1070
I5 6600K
That is really all that matters
that is all that really matters xD I think you could achieve 1440p easily.
https://linustechtips.com/topic/698994-help/#findComment-8940968
1 minute ago, wrathoftheturkey said:
Dude do you not check out ppl's profiles?
1440p is apparently definitely worth it.
hes new so I didn't know if he had it posted and I'm lazy xD
https://linustechtips.com/topic/698994-help/#findComment-8940978
https://linustechtips.com/topic/698994-help/#findComment-8940990
1 minute ago, ChiefRobb said:
That is the exact monitor I wanted, but it is too much, 849 cad dollars. I suppose I could get it, its really nice
https://linustechtips.com/topic/698994-help/#findComment-8941008
thats on sale from 800 USD! Yikes
https://linustechtips.com/topic/698994-help/#findComment-8941032
sorry
1 minute ago, Blue_Meanie said:
Well thanks for the info
https://linustechtips.com/topic/698994-help/#findComment-8941044
https://www.amazon.com/Asus-VG248QE-24-Inch-LED-Lit-Monitor/dp/B00B2HH7G0/?tag=amazon0606-20 this isn't anything amazing and its 1080p but its all you can find for cheep
https://linustechtips.com/topic/698994-help/#findComment-8941051
