So here we go. I made a short post about this earlier last month, but the topic has shifted quite a bit.
My friend currently has something like the ASUS M32BF-US006O:
A10-6700 w/ old AMD cooler
Motherboard w/ 1 PCIe x16 slot
PSU (must replace)
The M32BF case (must replace)
As you can tell, it's a pretty barebones system. His budget is roughly $250. At this point, it looks like he needs a new system, but a CPU + GPU would cost him above his budget for sure. He says he doesn't want to replace his CPU because it'd be expensive, but would it bottleneck the GPU? I'll let you guys experiment with the budget because I don't know anything about AMD CPUs.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/698904-help-with-upgrades/
Well it has a PCIE 2.0 x16 slot thats a start, thought it has a * beside it on the Asus website (idk why). It looks like its decent
Also there will always be a bottleneck, but I would go for the GTX 1050 Ti any higher and you will get almost nothing.
https://linustechtips.com/topic/698904-help-with-upgrades/#findComment-8940087
That's what I thought. Any input on anything else?
Skyggeis Specs:
https://linustechtips.com/topic/698904-help-with-upgrades/#findComment-8940106
Also, would he need a better cooler? AMD CPUs...
Skyggeis Specs:
https://linustechtips.com/topic/698904-help-with-upgrades/#findComment-8940112
