So I have a Focusrite Scarlett USB audio interface that I use with my Audio Technica m50x's, and I would like to upgrade my headphones to the HD600s. What DAC/ Amp do I need? I would like the cheapest option possible, if I need one at all. Can I use it with the Scarlett? (I assume I can't). Would something like the Schiit Magni/ Modi DAC and amp be good? Do I need both, or can I just use the amp?
Thanks
https://linustechtips.com/topic/698860-sennheiser-hd600-help/
Thanks
Is that only a preamp? (Focusrite Scarlett)
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/698860-sennheiser-hd600-help/#findComment-8939632
Yes I think so.
It should work with just your current gear. Here's a thread from *shivers* head-fi.
http://www.head-fi.org/t/709835/need-some-amp-help-with-hd-600
I also have a HD 600 and there not too hard to power.
https://linustechtips.com/topic/698860-sennheiser-hd600-help/#findComment-8939669
