Hey guys, so I just got a Trust GXT 30 controller very cheap without any accessories and stuff it says that it's wireless (i didn't get the USB receiver), but as you can see in the picture below it has mini usb port so I decided that it should work on it, but when i connect it to PC via usb nothing happens although when i press the home button in the middle it starts shining and blinking. So how do I make it work?
https://linustechtips.com/topic/69843-trust-controller/
The mini usb is probably only for charging.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/69843-trust-controller/#findComment-956776
Are you able to use the controller in a wired fashion? Is it something that's advertised?
https://linustechtips.com/topic/69843-trust-controller/#findComment-956885
