Looking at the ubiquity hi-range wifi that seems totally legit.
You don't just get the two dishes get however many sets you need, use them like most governments and militaries use microwave communication. LoS each dish to one another till it reaches your dish at the house.
2 minutes ago, Doublei7 said:
There are sewers but how do i use them on my advantage? I don't understand.
lay some cable, but it depends if its a pipe or something you can icognito get into and lay some cable.
i think your best bet is that wifi signal dish. do you have access to the roof where you are allowed to install a dish?
next up is the power line idea
I ain't sneaking lan cables on citys sewers, and it's illegal to do anything on the wall of  the building where my restaurant is, also it would look dumb and no way would it be allowed. So from what it looks like there's no hope
Unfortunately I do not see a way then. :(
You could pack up and move to the restaurant. :P
The shittiest part is, i almost got an apartment right  in front of the restaurant but smth went wrong or idk and i didn't get it.
