I've been wanting to upgrade my graphics card for gaming for some time now, although I have no idea what to go for, I was gonna go for the EVGA geforce gtx 1060 6gb model but then I got informed that I would be victim of some bottlenecking, please could someone suggest a mid-range graphics card I can get with my specs, with a budget of $200-$300
Specs:
CPU: AMD FX-6300
RAM: 8GB DDR3 @ 803Hz
MotherBoard: ASUSTeK Computer INC. M5A78L-M/USB3
GPU: 1024MB ATI AMD Radeon T5 200 Series.
Storage: 931GB TOSHIBA DT01ACA100
Monitors:
Samsung T24D390
Samsung S22D300
https://linustechtips.com/topic/698036-best-gpu-for-my-system/
5 minutes ago, Neihonix said:
so the 1050ti? will that not bottleneck? sorry I'm new to the hardware side of things
you should be just fine
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931812
Get an RX 470
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931818
Just now, Neihonix said:
ok, thanks a bunch guys, will this card be capable of running games such as overwatch and fallout 4?
at what resolution?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931822
why? does it have more of a benefit to me?
it performs better than a 1050ti yes
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931831
1080p, i dont go over that haha
you should be fine as long as you keep it in reasonable settings (medium to low)
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931835
1 minute ago, Neihonix said:
will it not bottleneck in my system?
it will bottleneck, you can oc your CPU so the bottlenecking wont be that bad
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931850
the 1050ti will bottleneck? or the 470? either way i dont really want to overclock, i usually mess things up
the 470, you will be fine with the 1050ti. if you are still concerned i would recommend a rx 460 (you will need to play in more reasonable settings since it is a weaker card)
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/698036-best-gpu-for-my-system/#findComment-8931874
