will it make any diference?
4 members have voted
  1. 1. will it make any diference?
    • yes worth 10 pounds more
    • no not worth 10 pounds more
      2
    • minimal difference worth 10 pounds more
      2
    • minimal difference not worth 10 pounds more
@Ethocreeper, definitely not worth it especially since 3000MHz is already a very high RAM clock speed of DDR4. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/697916-ram-speed/#findComment-8930820
9 minutes ago, Ethocreeper said:
but will it make any difference at all
Yes, but will you notice it? No
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/697916-ram-speed/#findComment-8930849
All else being equal it can make a small difference in ram intensive tasks. Emphasis on "small". I wouldn't worry about it.
https://linustechtips.com/topic/697916-ram-speed/#findComment-8930910
