Cable mod
Go to solution Solved by W-L,
8 minutes ago, Adrian91 said:
Hi there, i was just wondering which cablemods would fit on a EVGA QG 750w modular psu ? Ty.
Welcome to the Forums!
Cable Mod doesn't have a kit you can directly buy for that PSU but does have the option to customize your own with their cable configurator:
https://store.cablemod.com/configurator/
-Moved to Modding Section-
@CableMod should be able to help you.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/697823-cable-mod/#findComment-8929983
https://linustechtips.com/topic/697823-cable-mod/#findComment-8929989
