Hi,i am planning of upgrading my GPU to a GTX 750 TI and was wondering that it will bottleneck my CPU.I am also looking at CPU upgrade if i managed to find one(i5,i7). Any suggestion is very welcome,Thanks in advance.
Here are my current system specs:
Computer Information:
    Manufacturer:  BIOSTAR Group
    Model:  H55 HD
    Form Factor: Desktop
    No Touch Input Detected
Processor Information:
    CPU Vendor:  GenuineIntel
    CPU Brand:  Intel(R) Core(TM) i3 CPU         540  @ 3.07GHz
    CPU Family:  0x6
    CPU Model:  0x25
    CPU Stepping:  0x5
    CPU Type:  0x0
    Speed:  3076 Mhz
    4 logical processors
    2 physical processors
    HyperThreading:  Supported
    FCMOV:  Supported
    SSE2:  Supported
    SSE3:  Supported
    SSSE3:  Supported
    SSE4a:  Unsupported
    SSE41:  Supported
    SSE42:  Supported
    AES:  Unsupported
    AVX:  Unsupported
    CMPXCHG16B:  Supported
    LAHF/SAHF:  Supported
    PrefetchW:  Supported
Network Information:
    Network Speed:
Operating System Version:
    Windows 10 (64 bit)
    NTFS:  Supported
    Crypto Provider Codes:  Supported 311 0x0 0x0 0x0
Video Card:
    Driver:  NVIDIA GeForce 210
    DirectX Driver Name:  nvd3dum.dll
    Driver Version:  9.18.13.4196
    DirectX Driver Version:  9.18.13.4196
    Driver Date: 30 May 2016
    OpenGL Version: 3.3
    Desktop Color Depth: 32 bits per pixel
    Monitor Refresh Rate: 60 Hz
    DirectX Card: NVIDIA GeForce 210
    VendorID:  0x10de
    DeviceID:  0xa65
    Revision:  0xa2
    Number of Monitors:  1
    Number of Logical Video Cards:  1
    No SLI or Crossfire Detected
    Primary Display Resolution:  1920 x 1080
    Desktop Resolution: 1920 x 1080
    Primary Display Size: 18.78" x 10.55"  (21.54" diag)
                                            47.7cm x 26.8cm  (54.7cm diag)
    Primary Bus: PCI Express 16x
    Primary VRAM: 1024 MB
    Supported MSAA Modes:  2x 4x 8x
Sound card:
    Audio device: Speakers (Realtek High Definiti
Memory:
    RAM:  6071 Mb
Miscellaneous:
    UI Language:  English
    Microphone:  Not set
    Steam Controller Cable and Base:  Not set
    Media Type:  DVD
    Total Hard Disk Space Available:  552803 Mb
    Largest Free Hard Disk Block:  360636 Mb
    OS Install Date: Jan 01 1970
    Game Controller: None detected
    VR Headset: None detected
https://linustechtips.com/topic/697816-help-need/
