Radeon 480x worth it? (I freesync supported)
Solved by Morgan MLGman,
If you have freesync monitor, I guess you should just buy AMD cause variable refresh rates are great.
Look into R9 Fury deals, they're often at the price of a GTX 1060 6GB/ RX 480 8GB and it's a faster card than both of those.
