2 minutes ago, Zonehammer said:
https://au.pcpartpicker.com/list/ im thinking of getting this any suggestions plus need power supply and 16gb of ddr4
THE PSU is good, and I'd just stick for 16 GB if you have a 1070, doesnt make sense going lower with a 1070 imo
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/696082-help-with-build/#findComment-8915174
Just so ya know he put the generic part picker list link, so you're looking at whatever the last list you made/had open was xD
https://linustechtips.com/topic/696082-help-with-build/#findComment-8915183
3 minutes ago, Zonehammer said:
You did it again. Go to edit part list and copy permalink. Not the web browser link. Permalink is right above the green "all parts are compatible" notice at top.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/696082-help-with-build/#findComment-8915209
1 minute ago, Zonehammer said:
It is :P Whats your budget for it with the psu and ram added in?
without knowing i'd go for that - https://au.pcpartpicker.com/list/6xPDkT
Solid PSU, and good/cheap(ish) ram.
https://linustechtips.com/topic/696082-help-with-build/#findComment-8915233
oml i just cringed so bad
https://linustechtips.com/topic/696082-help-with-build/#findComment-8915702
