please help me with compatibility
Solved by Guest,
The recent FTW models have had some issues check with your store that they have the newer cards in stock before buying. The gpu will work with that board. The cpu however no its a 1151 socket and the board ony supports 1155 so find a different board that supports a 1151 cpu.
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
